Sign-in / Sign-up
Solved
USB problem: MAC
  • Flash Media
  • USB
  • Macintosh
  • Storage
Last response: in Storage
August 6, 2012 12:41:41 PM
I tried plugging a LEXAR USB into my MAC today, hoping it would work. The light on the USB drive comes on (and stays on as if its "charging" ). The USB shows up in disk utility, but gives me no option to select to verify/repair the disk.
I need the data off of this drive as it has all of my grade 12 assignments and study notes on it. PLEASE HELP!!!
More about : usb problem mac
August 6, 2012 1:46:48 PM
Check to see if the LEXAR USB is either formatted in NTFS or FAT, cause for me when I plug in a USB with NTFS format it won't let me open it as Mac does not support it.
m
l
Best solution
August 15, 2012 2:33:40 PM
Read this : http://freeware-recovery.blogspot. [...] overy.html
There are many useful informations in this lens and you will find a free data recovery software there. It is a handy software to recover lost data owing to many reasons like the one you met. The biggest advantage of this software is that it is FREE. So why not have a try? I bet you will love it.
Remember: Don't save important files in USB.
August 16, 2012 10:11:36 PM
Best answer selected by RShukla.
m
l
August 16, 2012 10:14:09 PM
Thank you very much. :)
I also was able to go to the computer technicians at school and they also managed to recover all my files.
Thanks for the answers.
m
l
