Hard Drive Problem Need Advice
Last response: in Storage
Related ressources:
- ForumHard drive blue scrren of death, Need advice
- ForumHard Drive Problem ? I Need Advice
- ForumNeed advice - hard drive setup for a new build
- ForumNew Build - Need Video Card/ Hard Drive Advice
- ForumNeed advice for new hard drive
- ForumUsing old hard drive as external. do you need to install an OS?
- ForumNeed help to recovery my data on my external hard drive .
- ForumNeed hard drive advice for Dell Inspiron 8200
- ForumNeed advice for software to test external hard drive
- ForumHard drive advice
- ForumAdvice needed with new hard drive installation on an old G..
- ForumNeed Some Advice ...1 Hard Drive or 2 Hard Drives
- Forum2nd Hard Drive dead in 2 weeks, need HELP!
- Forumneed advice on hard drive upgrade
- ForumFirst SSD advice?
- ForumCan i used sata 6Gb/s hard drive in Sata 6Gb/s Port
- ForumNeed hdd drivers
- ForumNeed help building a DLNA server!
- More resources
Read discussions in other Storage categories
). Anyway, I was frustrated and pressed for time (why I didn't RMA it then and there) so I opened the enclosure to find a WD Caviar Green 2TB drive which I hooked up through a SATA connection. It immediately showed up as a questionable drive in Intel Rapid Storage.
decided to zero-out the drive (took 8 hours). The drive then needed a MBR which went alright but now every time I try to format the drive, windows cannot.
