Sign-in / Sign-up
Changing HDD in Laptop without removing battery
  • Hard Drives
  • Laptops
  • Battery
  • SSD
  • Storage
Last response: in Storage
August 7, 2012 8:08:27 PM
I recently changed my Laptops HDD to a new SSD but when i removed the HDD from the laptop i forgot to remove the battery before i changed. Can this damage the HDD in any way? Worth mentioning is that apart from the battery not taken out, the computer was shut off.
The reason I'm concerned is that i cloned the HDD to the SSD after i removed it so I want to be sure that there isn't a big chance for corruption. When I installed the SSD into the laptop it booted up without problems/errors and the OS has been running fine since, just want to know if I should worry that something may be corrupt.
Thanks in advance!
More about : changing hdd laptop removing battery
a c 113 G Storage
a b D Laptop
August 7, 2012 8:37:07 PM
Don't worry as no power was applied to the hard disk or SSD.
m
l
