G
Guest
Guest
Hello,
Im trying to order parts to build my PC But I need a little Help I will first List my parts then ask my questions thanks
Processor - AMD Phenom II X6 1090T Black Edition Thuban 3.2GHz Socket AM3 125W Six-Core Desktop
Mother board -MSI 890FXA-GD70 AM3 AMD 890FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard
Graphics - -2 Of THESE in Crossfire-
GIGABYTE GV-R597D5-2GD-B Radeon HD 5970 (Hemlock) 2GB 512 (256 x 2)-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support ...
Sound Card - M-Audio US41077 Delta 1010LT PCI Virtual Studio Sound Card
Main Hard drive -
Crucial RealSSD C300 CTFDDAC128MAG-1G1 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD)
Secondary Drive-
HITACHI Deskstar HD32000 IDK/7K (0S00164) 2TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive
Power Supply -
CORSAIR TX Series CMPSU-950TX 950W ATX12V v2.3/EPS12V v2.91 SLI Ready 80 PLUS BRONZE Certified Active PFC Power Supply
Case-
Thermaltake Armor+MX VH8000BWS Black Aluminum / Steel ATX Mid Tower Computer Case
Item #: N82E16811133062
Other Things I ordered
1. CORSAIR Cooling Hydro Series CWCH50-1 120mm High Performance CPU Cooler
Item #: N82E16835181010
2. SYBA SD-SATA-4P PCI SATA Controller Card
3. (2X) Pioneer CD/DVD Burner Black SATA Model DVR-218LBK LabelFlash Support - OEM
4. LG 22X DVD Burner - Bulk Black SATA Model GH22LS50 LightScribe Support - OEM
5. LG Black 10X Blu-ray Burner - Bulk SATA Model WH10LS30 LightScribe Support - OEM
6. nMEDIAPC ZE-C128 Black Aluminum Panel 5.25"All-in-one USB x 3 / IEEE 1394 / eSATA / HD (or AC97) Audio Internal Card Reader
QUESTIONS----
1. Is everything here Compatible? (Not sure about the power supply as my mother board needs a 24 Pin and the Power block has a 20+4Pin Is that the Same??? and Can you have too much Power? like is a 950 Watt or 1200Watt PCU to much or any power supply is fine?
2. I'm having a problem with Ram I want 16 Gigs 4 X 4 for my mother board -This would be easy if i was building a intel based PC. but with amd I only have 4 Slots and a 16GIG max so i need 4GIG chips and every 4 Gig Chip says things like (Designed specifically for Intel P55/ H55/ H5) But the Pins -240- match so it should work . Any ideas I have looked into these rams so far
1. OCZ Reaper Edition 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666)
2. OCZ Gold 4 GB Memory - DIMM 240-pin - 1333 MHz ( PC3-10666 )
Any help with the Ram would be great ?
3. Besides the Stock Fans and this liquid cooling thing above Do i need any other cooling since i have 2 Very Large Graphics cards. Should I add even more fans or can i do liquide cooling with the graphic cards and Ram ???
Any Help WOuld BE Great
Main Hard drive -
Secondary Drive-
Power Supply -
Case-
QUESTIONS----
