So anyways, I bought all the parts, and then assembled them according to the manual in the case. I turn it on; the fans turn on and I hear the everything working fine for 2 seconds, then it turns off, so I completely disassemble the thing and put the motherboard on a cardboard box and take everything off except CPU and RAM and short the power pins to turn it on. Same thing. I've rearranged the RAM to every combo possible, with both 1 stick and 2 sticks. I checked the power supply, and it works on my old computer just fine. I've even gone as far as taking out the heatsink and removing and reapplying thermal paste on it. Still nothing. No beeps from the speaker, no nothing. The 4 LED lights do turn on though.
Specs:
Gigabyte GA-H55M-UD2H Motherboard
Intel i7 860 LGA1156
XION 630Watt PSU
(2) Corsair CM3X2048-1333C9DHX 2gb 1333Mhz 9-9-9-24 Dual Channel
I'm bummed. Anything else that I can do?
Specs:
XION 630Watt PSU
