Will a AMD 6950 1GB work fine in a PCIexpress x16 1.0 mobo?
Hi all
I have a C2D e6750 OC @ 3.12 Ghz and this motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813128059
Will this card http://www.newegg.com/Product/Product.aspx?Item=N82E16814150524 work ok in it? I know my CPU will be bottle necking the GPU a bit but I hadn't thought about my PCIexpress limitations until now.
Thanks much
1 answer Last reply
More about will 6950 work fine pciexpress mobo
  1. Your PCIe x16 slot will have no major bottleneck to your GPU. You will probably see only a few FPS decrease by running on PCIe x16 versus PCIe 2.0 x16
Motherboards AMD Product
