Yes No
Ads
Tom's Hardware > Forum > Motherboards & Memory > Motherboards > [Solved] I need help figuring out what is wrong in my system
Forum Motherboards & Memory : Motherboards [Solved] I need help figuring out what is wrong in my system
Best answer from anort3.
the system:
Mobo: MSI X58 Pro-E
CPU: i7 950
RAM:Corsair XMS3 6x2GB 1600MHz
PSU: Corsair 650TX
GPU: GTX 580
So I got this CPU to 4GHz but not 100% stable, I was getting some BSODs so I used memtest to test my memory, and turns out that was the problem. I set everything back to stock and then I started testing the sticks individually they all worked fine and passed with 0 errors 3 times each, then I tested 3 of them in triple channel, again they all passed, I tested the other 3 in triple channel and they also passed, but when I put all the sticks in and I get errors. I'm no expert and this is puzzling to me, I suspect my motherboard might be the culprit but I'd like to get a second opinion.
Reply to jorge89
You could very well have a bad memory slot. You might also need to bump the voltage running all 6 slots full. You try that?
------------------------------ i7 2600K @ 4.5/P67A UD4/Scythe Mugen 2 Rev B/OCZ Vertex 2 120GB/2xWD 640 Blacks/Antec 1200/Samsung 23in LED LCD/EVGA GTX 460/2x4GB GSkill Ripjaws X DDR3 1600 7-8-7-24/Windows 7 Ultimate x64/Corsair 750TX
Reply to anort3
The stock voltage is 1.65, how much higher should I try? I didn't know using 6 sticks required a raise in voltage.
Reply to jorge89
Best answer
I would not go beyond 1.65. I think it can damage the CPU. Is QPI set to 1.35v? And have you manually set the timings?
Reply to anort3
The QPI was set to Auto and so were the timings, the timings were manually set to the manufacturer's specifications when it was overclocked though. I'm going to test while the QPI voltage and memory timings are manually set, I'll report back when I'm done testing.
Reply to jorge89
So I tested them 5 times with the settings you recommended, 0 errors!
Is it normal to have to raise the QPI voltage to have stability in a system with 6 memory sticks? or is there something wrong with my motherboard? and what should be the highest safe QPI voltage when overclocking? I'm guessing that in order to keep my memory stable while overclocked I'll need to raise my QPI voltage even more. I don't mind keeping my memory at 1600MHz though but a little bump would be nice, I'm planning on having my CPU clocked to 4GHz if I can do so 100% stable.
Message edited by jorge89 on 03-14-2011 at 03:06:15 AM
Reply to jorge89
Its normal to have to manually set the QPI and timings when all the slots are populated.
Reply to anort3
Glad I could help!
Reply to anort3
Thanks for all the help, any idea of what the highest and safe QPI voltage could be for my system? in case I need to raise it.
Reply to jorge89
I am not sure of the max QPI. Google a bit and you will find it though.
Reply to anort3
This topic has been closed by Mousemonkey
------------------------------ http://img545.imageshack.us/img545/3995/bl11.gif
Reply to Mousemonkey
There are 2021 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Memory for GIGABYTE GA-G41MT-S2P
By fantastik250, 1 hour ago:
Take a look at this and see if you like it. http://www.newegg.com/Product/Prod [...]...
Best offers
Top experts
