Solved
Might be Power-Supply problem?
Last response: in Systems
June 17, 2010 2:09:08 AM
I just completed a new build. The problem is that when i turn on my computer, i see that the fans spin for half a second(power supply fan and the back fan). No display or beeps, then powers off. Could this be a faulty power supply or what? By the way the is from Cooler Master.
More about : power supply problem
Best solution
a b B Homebuilt system
a c 249 ) Power supply
June 17, 2010 2:15:43 AM
http://www.youtube.com/watch?v=5FWXgQSokF4
Take out a case fan and your PSU and test it as shown in that video, its by corsair but the trick works with any PSU.
June 17, 2010 2:24:24 AM
Thanks. It seems kinda risky but i'll give it a try.
June 17, 2010 2:29:17 AM
Its not at all risky, that is exactly what happens when you push the power switch on your motherboard, so there is no risk of damaging the power supply, and you are dealing with very low power available on the green wire.
June 17, 2010 2:30:42 AM
Best answer selected by inforedx.
