Closed Solved
1000w Psu enough power??
I am doing a new build for some one.My question is-I have a Silverstone DA 1000w PSU.Is this enough power for my build ?? The specs are- i-7 930,6gb F3 12800 CL8T G-Skill RipJaw series memory,Cooler MasterHyper212Plus cooler,EVGA #295 CO-OP Edition,BFG #260(using for PHYSIX),Asus ws P6T6 Revolution motherboard. Other stuff included in build is 1 extra case fan,Plextor B94OSA Blu-Ray burner,Silverstone Raven RVO1 case,WD 600Gb 10,000Rpm Hard Drive,Asus Xonar Dx sound card,23in Gateway LCD Monitor,speakers,kb,mouse. I was just hoping that the Silverstone 1000w is enough power.
12 answers Last reply Best Answer
More about 1000w power
  1. yes.. with that u can run 3sli or maby 4sli.
    yeahh it is enought power
  2. I'd say a healthy bit more than 'enough'. :)
  3. I'd honestly say that could be ran on a 750W power supply, so you have more than enough.
  4. i would agree with lone ninja. something like corsair 750w would do.
  5. A good 750-850 would be enough power for that rig - 1kW is more than enough.
  6. Best answer
    Which begs the question - is there such a thing as too much juice in a PSU? Anyway, there are good calculators online that give an *indication* to how much you'll need out of your PSU. Try:
    http://extreme.outervision.com/psucalculatorlite.jsp
    I checked New Eggs site and it said that the specs I have would use over 1000w.I thought that it would work well,but I just wanted to make sure.A 295 and a 260 in all is the equivalent to 3 260's.
  8. the newegg psu calc is retarded :)
    It seemed a little high.
  10. Best answer selected by seanny.
  11. you could add another 295 and still have enough power
  12. This topic has been closed by Mousemonkey
Power Supplies Silverstone Power Components
