Would this DvD Burner work with Windows 7 64 bit? In the specs it only goes up to Vista. Also do i need 2 drives or is that one alone enough?
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204&cm_re=ASUS_DRW-24B1ST%2fBLK%2fB%2fAS_Black_SATA_24X_DVD_Burner-_-27-135-204-_-Product
