Solved
Graphic card help
hello and thanks for everything i think i finally found one does anyone know if this is a good card its a RADEION HD 4350 1024 DDR2 PCIe 2.0X16 59.99 microcenter in cincinnati oh its in my price range and i think it will fit my pc i have a dell model 530 desktop its got a 750 gig hard drive and 6 gigs of ram this i was told will play about every game out there any help ill apprecitate it and thanks again yall rick hill
7 answers Last reply Best Answer
More about graphic card help
  1. The 4350, simply put, is a piece of trash. It'll do fine for watching DVDs, but you will be hard pressed to play new games with it. It will play the games, maybe, at the lowest settings possible, but if you want a decent card, go for the 4650 or 4670; the 4650 should cost about $50, the 4670 about $70.
    Beware, though, that if you do get the 4650 or 4670 that your power supply better have enough wattage to handle it. Can you list your computer's specifications?
  2. if you want to buy a card, then tell us the rest of your specs, CPU, RAM, PSU, monitor, motherboard...
    And also how much do you want to spend?
    HD4350 is not good at all, if you want gaming then get higher card, like HD5770...
    hi thanks i have a 300 watt ps and a 19 inch dell flat screen monitor i dont know how to get the other specs i would like to spend around 75 bucks im on a fixed income
    thank you rick hill
  4. Best answer
    The 4350 is good for older games, but it won't really play any recent games. It probably can't even get through Mass Effect 2 on the lowest settings. If $60 is your price range then you should be looking at a 4670
    BIOSTAR VA4673NH51-B Radeon HD 4670 512MB $62.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814141114
    Which is enough to play most games on at least medium settings at 1440x900.
  5. Or for a few bucks more, get the HD5570. It will perform just a little better than the HD4670 but at least is a newer series and will consume considerably less power than the HD4670.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814131343&cm_re=ATI_graphics_card-_-14-131-343-_-Product
  6. the megamannx should be a teacher smiles i think ill get the one at newegg and give it a shot thanks everyone rick hill
  7. Best answer selected by rick30062001.
Graphics Cards Graphics Product
