Sign-in / Sign-up
Monitor problem
  • Nvidia
  • Monitors
  • Graphics
Last response: in Displays
Anonymous
a b C Monitor
May 12, 2010 4:57:01 PM
Hello,
once i installed a graphicc card my monitor would not stay on. It kept shutting down. What do you think the problem could be?
More about : monitor problem
a b Î Nvidia
a b C Monitor
May 12, 2010 7:27:12 PM
Did you install the card's driver?
what card?
m
l
a b Î Nvidia
a b C Monitor
May 12, 2010 8:45:55 PM
Sounds like a bad GPU. Does the monitor turn on during the DOS Prompt and BIOS screens? At what point does it shut down? (I'm assuming the monitor is putting itself into Standby mode?)
Double check to make sure your GPU has all the proper power connections made.
m
l
