Yes No
Ads
Monitor Display Help
Forum Graphics & Displays : TV Tuner Cards Monitor Display Help
Hey All,
I know this site is mostly catered to PC, but I have an Xbox 360 question that I think is somewhat related. I'm trying to find a way to decrease the viewing area of my 23" Acer monitor. When I play FPS games, I feel like 23" is just too big, and that having a smaller area would be easier. However, I can't seem to find a way to make the screen image smaller user the monitor buttons or tweaking the xbox. Any suggestions as to how I can do this or what I am missing? I have an Acer H233H monitor. In the monitor menu there is the option to adjust H.Size and V.Size, which I am assuming is what I want to change, but both of those options are 'greyed' out in that I can't select them. Any help would be great!
Reply to vanbuskirks
Try setting your Xbox 360 to output 720p. If you're connecting it directly to the monitor, the monitor should have a "1:1 mode" or similar to add black bars around the image instead of stretching it in both directions to fill the screen. If you're connecting it through a capture card on your computer, you may be able to do something similar with your video card settings.
Reply to MauveCloud
Hey, thanks for the tip, but unfortunately it did not work. I wasn't able to find anything about 1:1 mode on the monitor menu. I was able to change to 720p though. The monitor menu is utterly basic and really frustrating. Any other tips would be great!
Your monitor may not support a 1:1 mode. I have been unsuccessful in finding an online copy of the manual for it, so I can't confirm that. However, you mentioned grayed-out options for H.Size and V.Size. That may be available for a different connection type. What are you currently using to connect your Xbox 360 to this monitor?
Reply to MauveCloud
Tom's Hardware > Forum > Graphics & Displays > TV Tuner Cards > Monitor Display Help
There are 2027 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Graphics Card Help for a Casual
By geofelt, 1 hour ago:
As a standard, a pci-e x16 graphics card slot can deliver up to 75w to a graphics card...
Best offers
Top experts
