Considering GPU Upgrade (Extreme System)
Please see system spec below. Is a GPU Upgrade required for the display size I am running, Mostly running FPS, but getting lower than desired FPS in alot of the new games. Is it worth going to GTX 4** or Radeon 5*** Series?
CPU: - Intel I7 920 D0 Stepping Retail Processor @ 4.2GHz (200*21 : 1.30 vCore)
MB: - Asus P6T6 WS Revolution (16*16*16 NF 200 Chip)
RAM: - 6Gb Corsair Dominator 1866MHz RAM (3x2Gb)
PSU: - Cooler Master 1100w UCP Power Supply
SSD: - 2x Intel X25 80Gb in RAID 1
HDD: - 4x Western Digital Black 640Gb 7200RPM 32MB Cache in RAID 0
GPU: - 3x Asus nVidia GTX 260 216, (Overclocked to 725 GPU / 1125 Memory / 1450 Shader)
CHASSIS: - Antec 1200 Full Tower Case
OPTICAL - LG 22xDVD+RW
SCREEN: - 3x Dell E228WFP 22" Monitors @ 1680*1050 @ 59Hz (Total Single Display of 5040*1050, 5292000 Pixels)
DISPLAY: - Matrox Triple Head to Go Digital Edition
RAD: - Hardware Labs Black ICE GT Extreme Radiator 360 (120.3)
PUMP: - Swiftech MCP655 Pump
RES: - Swiftech MCRES-Micro Rev.2
CPU BLock: - Swiftech APOGEE XT CPU Water Block
MIC: - Logitech USB Microphone
KB: - Logitech Illuminated Keyboard
MOUSE: - Logitech G5 Mouse
PAD: - Steel Series Ice Mat
SOUND: - Sennheiser HD595 Headphones
Screen resolution gives me about 2.2x the amount of pixels you get on a 1080p monitor.
12 answers Last reply
More about considering upgrade extreme system
  1. Well it really depends on what is your budget. Because if you just want to run a single card a ati 58xx or 5970 would be the best option because it has eyefinity to run the 3 monitors, if you want the best you can get probably it would be 3 or 4 gtx 480.Though with the 4xx gtx series they need to be in SLI to run 3 screens. If you really don't have a budget limit go with either two 5970's or 3 or 4 gtx 480's.
  2. Should I upgrade or wait for next gen?
  3. A single 5970 would do very well at that res, but you could always get two if you want even more performance.
  4. a 5970 is no faster than 3x260s
  5. Yes it is.
    a 5970 has two 5870's on a single card. a 5870 is almost as powerful as a GTX295 (which contains two GTX260 chips)
  6. Actually a GTX 295 contains 2x275 but clocked at 260 levels with 240 stream processors.
    a 5970 is basically 2x5870 but they are down clocked to 5850 levels due to heat and power issues, and 3x260s are alot faster than 2x5850s (i know, i have 2x5850s as well and vantage will net me +3000 pts with the 260s)
  7. TBH, i might have a stupidly good pc, but im not made of money, i would as stated; need to go to 2x5970s or 3/4 GTX480 to see notable gains. tho adding a 3rd 5850 and swapping them back to this system would seem to be about the best option for money spent.
    Yes, but returning it to 5870 levels is as easy as the flick of a (virtual) switch.
    But yes, you would need a second card to have a big increase.
    interesting I would usually ask for proof but that is interesting enough to find out myself
    ha the link I found was toms article
  10. Go take a look at Futuremark ORB, my above system, gets just shy of 32000 points. thier is a CF 5970 on thier with only 34000
  11. If you have been out of the loop for a while, Vantage is NOT an accurate measure of system performance when comparing ATI to Nvidia. its HEAVILY nvidia skewed.
  12. Assuming PPU disabled, its not to far off.
New Build GPUs Systems
