Will this power supply support a 5770 graphics card?
  • Power Supplies
  • Graphics Cards
  • Fan
  • Support
  • AMD
  • Components
  • Product
Last response: in Components
August 19, 2010 4:07:36 AM
FSP Fortron SAGA AX450-PN 450W ATX12V 2.0 20/24PIN Power Supply W/ 120MM Fan P4 AMD Ready Retail
Link here:
http://www.directcanada.com/products/?sku=11730AC2682
More about : power supply support 5770 graphics card
a b ) Power supply
August 19, 2010 4:19:36 AM
Chinaware
Daammm that website is overpriced...*I assume its just cus it cost more to ship to Canada*
Try a good brand like CORSAIR.
m
l
a b ) Power supply
August 19, 2010 4:21:58 AM
Lmeow said:
It might, but I wouldn't trust those kind of PSUs.
This is much more trustworthy and would have no problem with an HD 5770. It's only a few dollars more after MIR.
http://ncix.com/products/?sku=33357&vpn=CMPSU-400CX&man...
He should get atleast a 500w PSU for his 5770.
Also get it from a good brand: Antec EA/ NEO/ TruePower Series, Corsair, Seasonic, Silverstone, CM Realpower/ Silent PRO, PCP&S, OCZ(Make sure you get the 80+ Certified ones)
m
l
August 19, 2010 4:30:12 AM
What is a good psu could someone recommend me one to buy I was thinking 650w tx corsair but it is a bit expensive and might be too much power.
m
l
a b ) Power supply
a b U Graphics card
a b À AMD
August 19, 2010 4:30:58 AM
^ I've heard of people running HD 5770 CrossFireX on a Corsair 550 W PSU. In reality the whole system with an HD 5770 would use less than 300 W. The extra 200 W is just to be safe.
m
l
a b ) Power supply
a b U Graphics card
a b À AMD
August 19, 2010 4:35:02 AM
The Corsair CX400 I linked you would be more than enough, if you plan on CrossFireX you'll want a 500 W - 600 W PSU to be safe.
m
l
a c 275 ) Power supply
a b U Graphics card
a b À AMD
August 19, 2010 5:53:07 AM
I'm Canadian and i'll set you up guy!
OCZ ModXStream Pro 600W i have one of these in a rig stay away from the stealths they suck.
http://www.directcanada.com/products/?sku=13220AC8686&v...
Corsair VX450 450W
http://www.ncix.com/products/index.php?sku=25472&promoi...
Antec Earthwatts 650W
http://www.ncix.com/products/index.php?sku=30037&promoi...
OCZ FATAL1TY 550W
http://www.directcanada.com/products/?sku=13220AC3355&v...
OCZ ModXStream Pro 500W
http://www.directcanada.com/products/?sku=13220AC0017&v...
All the linked units are good quality and some may be higher wattage but that gives you more leeway for future up-grades.
The Antec is a steal at that price only thing is it's not a modular cable system neither is the Corsair.
They are high quality units though.
The OZC are all 80% modular which makes for an easier install the Fatal1ty is probably the best bargain of the OZC''s.
m
l
August 19, 2010 6:49:07 AM
Corsair VX450 450W
OCZ FATAL1TY 550W
Wait so stay away from stealth and mode because you said "one of these".
Just want to make sure though I think you only meant stay away from stealth
m
l
a b U Graphics card
a b À AMD
August 19, 2010 11:14:27 AM
Yes the one you asked about which was a StealthXtreme from Newegg and that line of psu's does suck /the ModXtreme's are fine that i linked as is the Fatal1ty.
Found a better deal on the OCZ ModXStream Pro 600W
http://ncix.com/products/index.php?sku=33041&vpn=OCZ600...
And what i wrote is i have a ModXtreme 600w and linked one cuz they're good.
m
l
