First Post and First Build: seeking advice.
Hi all, I’m looking to replace my ooold dinosaur of a rig with a new one for the purpose of gaming, general use, and probably some photoshop and rendering down the road. I plan on having it for a while and want quality parts, but want to save on money where I can.
>Would be running on a 24 inch 1920 x 1080 display.
>I also don’t plan on over clocking any time soon.
>My budget is roughly $1300 max
Case:
>I wanted something with good cooling and dust filters, noise reduction would be nice but not necessary
>I really like the ft02 but don’t know if I can justify the price.
>Also, I looked at the antec p193 but the lack of included front fans and a hole for the cooler retention plate kind of turned my off, but feel free to convince me.
Cooler Master Storm Sniper black (includes 200mm side fan)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119194
price - 129.99 after MIR & w/ free shipping
Or
Silverstone fortress 2
http://www.newegg.com/Product/Product.aspx?Item=N82E16811163161&cm_re=ft02-_-11-163-161-_-Product
price – 249.99 w/ free shipping
Mobo: I’m looking to do a 1156 i7-860 build to save some money over a 1366 build, and since I don’t plan on using multiple graphics cards, I feel this is acceptable. I also like the support for sata III and USB 3
Asus p7p55d-E Pro
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131621
price – 179.99 but combos with my psu for a instant $50 discount & free shipping
PSU: Corsair hx 650 watt
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139012
price – 99.99 after $20 MIR & w/ free shipping
Memory: G.Skill ripjaws 4GB 1600, 7-8-7-24-2N timings
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231303
price 109.99 w/free shipping
Graphics:
>Tough choice, between 5870 and 470. I feel the 470 has more potential and CUDA would be a + for my rendering down the road and I do like the support of Nvidia.
>The power draw and heat is a bummer though.
However the evga 470 it is on sale for 329.99 and comes w/ just cause 2.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130550&cm_re=470-_-14-130-550-_-Product
Optical drive: don’t need anything real fancy, will a Samsung SH-S223L do?
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151188
!!!PRICE SO FAR!!! (with storm sniper and i7-860 included):
>$1,105 approx after MIR
Here’s where it get’s fuzzy…I’m not sure what to do about a cpu cooler or hard drive.
I was going the get the hyper 212+ until newegg price gouged it to 70 bucks
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065&cm_re=212_hyper-_-35-103-065-_-Product
I want something with pwm and would prefer it to be kind of quiet, not sure If I need to buy aftermarket thermal paste or not…I also want it to fit with my ram.
>any advice would be much appreciated.
Also, I want to do a 2 hard drive setup, I suppose. One for OS and apps and other for storage. I would like to to be fast.
>any recommendations?
So that gives me a budget of about 200$ for hard drives and cpu cooler.
I would love and welcome any help.
6 answers Last reply
More about first post build seeking advice
  1. Your going to want to go with FERMI and Intel on this one!
    Will post with more updates and help for you soon.
  2. Also, Would just 1 hard drive in partition be okay, or would that suffer in speed?
  3. Here's the build I made for you and your purposes considering I use all the above you posted on my build!
    DVD Burner $20.00 with Free Shipping:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16827118039
    Case and PSU $190.00 before rebate:
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.410715
    CPU and Motherboard $403.00:
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.404717
    Hard Drive $65.00 with Free Shipping:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822148433
    Memory $110.00 with Free Shipping:
    Graphics Card 250.00 with Free Shipping:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814130555
    Your total price is only: $1038.00 before rebates.
    Well I hope you like this build for the price.
    If you have any questions just post em.
  4. One Hard Drive is fine just have to make sure its 7200RPM or higher.
    As far as DVD Burners dosn't really matter would like it to be 24x for speed.
    As for the GPU as long as its a FERMI, I wouldn't worry to much.
    As for the CPU just make sure your getting the i7 its about the best CPU on market.
    As far as Cooler are conserned I've always just used the stock Coolers unless I know for a fact I'm overclocking.
    If you have any more questions just ask :)
  5. If you are not overclocking, the stock cooler is fine. If you are:
    http://www.frostytech.com/top5heatsinks.cfm
    And because this is your first build, take a look at this while you are waiting for your parts:
    http://www.tomshardware.com/forum/261145-31-read-posting-boot-problems
    It's our standard troubleshooting thread, but the first part has a checklist that may stop you from making some noobish mistakes.
    +1 :)
New Build Systems Product
