Welcome to Tom's Forum!
You won't save anything, and like domino's if the (1) one PSU fails then 4 MOBOs will also fail, and worst if the single PSU suffers a catastrophic failure then potentially poof goes 4 MOBOs, 4 GPUs, 4 sets of everything.
You can have a 3000W PSU and if the 'PC' draws only 200W then that's all the power that will be drawn from the PSU.
EACH connector from the PSU would be required to handle the AMPS X 4 / Connection. This on so many levels is a really bad idea. Don't do it...
