Solved
Fan speed for HD4650
  • Radeon
  • GPUs
  • Fan Speed
  • Graphics
May 14, 2010 8:21:13 AM
Hi,
CCC shows 4650 GPU temp is 50c when it is idle and fan speed is 50%.
But one month ago my GPU temp is 46c with that setting.
When I play game(Fallout 3), its temp is 60c with 50% fan speed currently.
I change my fan speed at 80%.
Do i need to set fan speed at 100%?
More about : fan speed hd4650
Best solution
May 14, 2010 10:12:39 AM
No, you don't. And 60c is very fine for the card. I found its high pitch to be rather annoying.
May 14, 2010 11:27:53 AM
your temps are good...don't worry about it.. :)
m
l
May 27, 2010 5:20:39 PM
Best answer selected by mubin.
m
l
