I received the parts for building my new PC today and have a question on how I should configure my HDDs.
I am loading WIN7 and Adobe CS5 Production Premiere on this PC that will be used primarily for amateur video production. The question has to do with the two Samsung F3 1TB HDDs that I ordered
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185&Tpk=samsung%201tb%20hdd%20f3
Question: Should I load the software on one HDD and use the other for storage? or should I partition one HDD with about 100GB for software and the other 900GB for storage also? Or should I do a Raid of some sort? I greatley appreciate any advice as I want my system to operate efficiently.
My system looks like this if it is important to the issue:
AMD 955 Quadcore 3.3Mhz CPU
4GB DDR3 1333Mhz RAM
Thank you! -Michael
Thank you! -Michael
