Specs first
Corsair TX750 750W
Intel Core i7 950 3.06 GHz BOX
Gigabyte GA-X58A-UD5
Patriot DDR3 2x2048MB Viper Series 1600MHz CL 7.0
Sapphire Radeon HD 5970 2GB DDR5 PCI-E FBOX
So I got all the parts today, put them together, and it didn't post. Okay, back to square one. I removed everything and was about to pull the mobo out of the case when I realized I haven't plugged the CPU power cable Riiight. Since I ripped everything out I decided to go slow and check everything just in case. I've plugged the CPU power cord in, powered up and... okay, the CPU fan goes sloooow and I'm getting a C1 POST error, no beep. Bad. I've put in a single mem stick in and the machine actually turned off on it's own after hitting C1 again for a second. Worse.
So, am I correct in blaming the PSU, or could it be something else?
Corsair TX750 750W
