Using a PS3 and a computer on one monitor
  • Tuner Cards
  • Speakers
  • Monitors
  • HDMI
  • Graphics
May 15, 2010 7:33:46 PM
I have no problem connecting them both to the same monitor using hdmi and dvi... but its the sound I am confused about.
I would be getting a monitor without speakers. Plugging my speaker system into the green socket on my PC, how would I get the sound from my PS3 onto the same set of speakers?
I know I could get a TV but they are a lot more expensive.
I also heard that HDMI is faster than DVI so would it be worth connecting them both via HDMI (GPU has a HDMI slot).
More about : ps3 computer monitor
a c 79 C Monitor
May 15, 2010 8:10:49 PM
If the monitor has an HDMI port but no speakers, it should have an audio output port (maybe marked as a headphone jack). I think then you'd need to feed that audio output to your PC's input, or get a y-adapter to combine them to your speakers. I've considered this myself in case the repair on my Gateway XHD3000 fails, which would mean I'd have to get a Dell 3008wfp to replace it. Unfortunately, my speakers only have 3.5mm male plugs, so I'd need a y-adapter with a female output, and I haven't found one.
May 16, 2010 4:27:52 PM
Ok, I'd like help choosing a Full HD 22" monitor below £150 pounds.
I have been looking at these two LG's - which one would be better generally and for gaming and movies?
Im looking at contrast ratio and response time.
There is a £13 price difference and the main difference is that one is LED. Is it worth investing in this improving technology?
LCD:
£137
LED:
£150
My GPU has spare DVI and HDMI outputs. (Its a HD 4850). I would want at least one HDMI input on the monitor which can be used for the PC for the time being and maybe a PS3 in the future (moving the PC to DVI).
There is also a viewsonic - slightly above budget - that may have better specs:
And Samsung which, I don't think is as good value:
