Solved
Radeon HD 5770 Crossfire vs. Radeon HD 5850 vs. Radeon HD 5870?
  • Graphics Cards
  • HD
  • Radeon
  • Graphics
May 15, 2010 9:19:13 PM
which will give better performance for gaming on a resolution of 1440 x 900? Cpu is a Phenom II X4 955 @ 3.8 GHz
More about : radeon 5770 crossfire radeon 5850 radeon 5870
a b U Graphics card
May 15, 2010 9:37:10 PM
You still haven't picked a GPU yet? ;)  How many threads does it take? LOL
@ 1440x900 you only need ONE HD5770. Anything more is fairly overkill.
HD5770 Crossfire = HD5850 < HD5870
m
l
May 15, 2010 9:38:19 PM
Well I want to run FSX with everything maxed out and REX 2.0 and add on's but I don't think the 5770 will get it done very well...
m
l
Best solution
a c 190 U Graphics card
May 16, 2010 1:45:17 AM
FSX is a CPU demanding game and you have a great CPU there, so don't worry about that... :)
For your resolution, a single HD5770 is more than enough, believe us. :D
Go for HD5850 or HD5870 if you on a plan to get a bigger monitor.
May 16, 2010 4:51:56 AM
I don't know about a bigger monitor but I might choose a different resolution though... Is resolution based off of monitor size or the type of resolutions your graphics card can be compatible with the monitor?
m
l
May 16, 2010 5:18:33 AM
Yup, with bigger monitor you can go with higher resolution, for 17" monitor = 1280x1024, for 22" monitor = 1920x1080.
m
l
May 16, 2010 7:04:31 AM
Best answer selected by JuicyCrapachino.
m
l
a b U Graphics card
June 9, 2010 7:18:00 PM
[Most] tests that I've seen show the 5770 CF >= 5870 AND you'll $AVE $$ ($100 w/5770 CF) ;)
I assume that you "might" upgrade your monitor, adding another $160 to $300+ to your budget, if considering the HD 5770 CF <or> HD 5850 <or> HD 5770. Clearly, if you KEEP your monitor then a single HD 5770 would be more than good. The tests that you see, read or watch on Youtube typically have monitors 22"-24" with resolutions of 1680 x 1050 -> HD 1920 x 1080, or greater.
At minimum going from a 1440X900 to a 1920X1080 requires TWICE the number of pixel calculations! IF you are buying a monitor then I'd recommend a true High Definition (HD) 1920 X 1080, I "personally" prefer the 24" variety.
Good Luck!
Footnote:
Bang for your Buck setup's:
(1) Single Monitor non-HD 1440X900 -> (1) HD 5770
(1) Single Monitor HD [1920X1080] -> CF HD 5770 (x2) or HD 5850
(2) Two Monitors HD [1920X1080] -> CF HD 5850+ (x2)
(3) Three Monitors HD [1920X1080] -> Triple CF HD 5850+ (x3)
Yep, people Triple CF/SLI GPUs to a single Monitor to achieve "wacko" FPS. If you can sustain 30-40 FPS then anything more is simply bragging rights - period! The Human eye can only process 25 FPS and see "jumps" in the rendering; the sudden jumps or lagging frequently is from loading lags from your HDD which is another reason Gamers like SSD (Solid State Drives) and/or CPU - bottlenecking.
m
l
