Okay so... I have been out of the game a LONG time. Christ last I was in it, the GTX295 was god. Now there's like GTX400 series! Anyways, as a result, I'm once again blown over by the amount of choices I have.
Now my plan is to build a semi-new rig. I will be keeping:
-Hardrive(s): (1TB Caviar Black) + 250GB WD piece of *** for backup
-Video card: (EVGA GTX275)
-and MAYBE my case: Antec 300 Gamer
Now, case room aside (I'll figure that out myself later) here's my few questions:
1. I've been doing some looking around and it seems that there's a few CPUs out there that caught my eye. In terms of perf/price.
-Core i7 920 (for under $300)
-Phenom II X6 1090T (for a bit over $300)
-The Phenom II X4 965 (around $200)
But my real question is what would you personally recommend? Is i7 better than X6? What's the difference between the AMD and Intel i7 and X6? Looking to spend under or around $300 on CPU
2. A decent, solid motherboard to go with the rig that isn't too fancy on features, but does support OCing a bit? Obviously, pick one that's compatible with the CPu and RAM you recommend. Looking to spend around or under $200
3. It seems to me RAM has had some ridiculous price drops. Whats a good speed RAM for gaming? I heard 1600 is alright and pretty cheap. Looking to spend under $200 here
In terms of power supplies and all the other little nicknacks I can figure that out myself, but I'm honestly blown away with how much new tech is on the market and I really don't know where to turn. Tom's charts seem to show that for the price you pay, the i7 I was talking about had better perf/price. But all my friends recommended AMD.
But honestly, I'm just spitballing here, I really don't know what's what anymore lol. So feel free to tell me what parts YOU recommend and why.
PS: If I get a new rig do you think the GTX275 could bottleneck the whole thing?
Thanks Tom's, you guys are ALWAYS helpful
