Solved
Power Supply
I am building a new rig with the 980x and a 465GTX video card. I want to know if a 850 PSU will be enough? I am not over clocking the CPU.
7 answers Last reply Best Answer
More about power supply
  1. Best answer
    Depends on the 850W PSU, which one are you planning to get? A good 850W unit will be wayy more power than you need, and even a good 550W unit would be able to run it, but there are some crappy 850W units that are only as powerful as a good 650W unit.
    I have a Thermaltake 850 toughpower that I am using from my old build.
    http://www.techaddicts.net/reviews/tt_tpower850w/tt_tpower850.html
    This is my new build:
    1. EVGA X58 FTW3 132-GT-E768-KR LGA 1366 SATA 6Gb/s USB
    3.0 ATX Intel Motherboard
    1. EVGA 01G-P3-1465-AR GeForce GTX 465 (Fermi) 1GB 256-bit
    GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video
    Card
    1. Intel Core i7-980X Extreme Edition Gulftown 3.33GHz LGA
    1366 130W Six-Core Desktop Processor BX80613I7980X
    CORSAIR DOMINATOR 6GB (3 x 2GB) 240-Pin DDR3 SDRAM
    DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory
    1. 80GB SSD new
    1. 80GB WD 10,000rpm Raptor old
    2. 24x DVD/RW drives old
  3. Your power supply you have is more then plenty for your new build I would not change it you could even add another 465 and still have plenty to spare.
    I was thinking of adding a second video card later so that is kool. thx!
  5. Get rid of that GTX465.. Its inferior on every aspect when compared to the GTX460..
  6. Your PSU is powerful enough for you config and even dual cards :)
    I also suggest you GTX460 over GTX465 if you haven't bought it yet...
  7. Best answer selected by gunsnbabes.
Power Supplies Graphics Cards Components
