Uninterruptable Power supplies
  • Homebuilt
  • Power Supplies
  • Corsair
  • Systems
  • Product
Last response: in Systems
June 24, 2010 2:53:14 AM
Hello, I'm considering a UPS Power supply and want an adequate amount to back up my 750 watt corsair supply. Do I need the equal wattage in the ups? If not then what needs to be considered when determining a ups for my needs. I don't really care much about battery life in the event of a power failure as much as I do WANT TO PROTECT MY PC FOR A GRACEFUL SHUT DOWN.
I'm asking because these UPS supplies are pretty expensive I want enough to protect and dont wanna waste money.
Thanks in advance.
gerry
AsRock x58 extreme
core i7 930
stock intel cooler
radeon HD 5850
corsair TX 750 ps
dominator tri channel 1600
wd 1 TB
More about : uninterruptable power supplies
a c 90 B Homebuilt system
a c 139 ) Power supply
June 24, 2010 2:57:14 AM
You only need to match the UPS to your actual power draw - not the size of your PSU.
Will you need to plug your monitor into the UPS? If so list the make/model.
m
l
June 24, 2010 3:07:28 AM
I have a samsung syncmaster 906 bw.
thanks for your help
m
l
