My $640 Build (need some advice)
Last response: in Systems
Hey guys here is a pic of my build that I have been working on. First off I want to know if everything is compatible. Secondly, the reason I have a 750W PSU is because I want to upgrade in the future to dual 5770 and also more memory. Is the PSU sufficient enough for that? This all come to $640 after MIR and free gift card. Thanks for the help and check it out!
THANKS :bounce:
More about : 640 build advice
dark_lord69 said:
I don't see a "pic"
It should be there I have checked with more than one computer. I will post url link when I get back home.
Thanks for the heads up
Related ressources
mosox said:
600W is enough for your crossfire. For gaming more than 4G of RAM doesn't help.
Ya, i do more than gaming. I use Photoshop, FRAPS, Vegas, 3dsmax, and I do a bit off multi-tasking while programming in C/C++/Python/Java and other sorts of web development.
Are you sure 600W is enough?? I want to be sure before I make a final decision on what PSU.
Thanks
You're doing something wrong in there. A HD5770 consumes 108W in load. Two of them, 216W. Add the 125W of the CPU and 50W for all the rest and you're under 400W. 550W-600W is fine.
Ok thanks
Can someone help me find a PSU on newegg or tiger that will be sufficient and cheap. I can combo up with cd/dvd burner or Hard Drive if you find a deal.
Please help me find something at a decent price above 500W.
Thanks
Ask the community
