Desktop PC won't power on - CPU or MOBO?
Hey everyone,
After a bad storm in Orlando, my computer will no longer turn on. I tried replacing the power supply and reseating the memory. I also tried only using one stick of memory and I still can't get this thing to power on. When I switch the power supply on, a Yellow LED comes on on the MOBO - I believe this just indicates standby. What should I try doing to fix this thing?! Thanks
Here are the specs:
MSI P6N SLI Platinum LGA 775 NVIDIA nForce 650i SLI ATX Intel Motherboard
Core 2 Duo Processor E6750, LGA775 2.66GHz
G.Skill DDR2 Series F2-6400CL5D-4GBPQ - Memory - 4 GB : 2 x 2 GB - DIMM 240-pin - DDR2 - 800 MHz / PC2-6400 - CL5 - 1.8 - 1.9 V
MSI NX8600GTS T2D256E-OC
1 answer Last reply
More about desktop power mobo
  1. Work through our standard checklist and troubleshooting thread:
    http://www.tomshardware.com/forum/261145-31-read-posting-boot-problems
    I mean work through, not just read over it.
    Breadboard - that will eliminate any kind of case problem you might have.
    http://www.tomshardware.com/forum/262730-31-breadboarding
    Breadboard with just motherboard, CPU & HSF, case speaker, and PSU. You do have a case speaker installed, right? If not, you really, really need one. If your case or motherboard didn't come with a system speaker, you can buy one here:
    http://www.cwc-group.com/casp.html
    You can turn on the PC by momentarily shorting the two pins that the case power switch goes to.
    You should hear a series of long, single beeps indicating memory problems.
    Silence indicates a problem with (in most likely order) the PSU, motherboard, or
    CPU. Remember, at this time, you do not have a graphics card installed so the load on your PSU will be reduced.
    If no beeps:
    At this point, you can sort of check the PSU. Try to borrow a known good PSU. If you cannot do that, use a DMM to measure the voltages. Measure between the colored wires and either chassis ground or the black wires. Yellow wires should be 12 volts. Red wires: +5 volts, orange wires: +3.3 volts, blue wire : -12 volts, violet wire: 5 volts always on. Tolerances are +/- 5% except for the -12 volts which is +/- 10%.
    The gray wire is really important. It should go from 0 to +5 volts when you turn the PSU on with the case switch. CPU needs this signal to boot.
    You can turn on the PSU by completely disconnecting the PSU and using a paperclip or jumper wire to short the green wire to one of the neighboring black wires.
    http://www.youtube.com/watch?v=5FWXgQSokF4&feature=youtube_gdata
    This checks the PSU under no load conditions, so it is not completely reliable. But if
    it can not pass this, it is dead. Then repeat the checks with the PSU plugged into the computer to put a load on the PSU.
    If the system beeps:
    If it looks like the PSU is good, install a memory stick. Boot. Beep pattern should
    change to one long and several short beeps indicating a missing graphics card. Silence or long single beeps indicate a problem with the memory.
    Insert the video card and connect any necessary PCIe power connectors. Boot. At this point, the system should POST successfully (a single short beep). Notice that you do not need keyboard, mouse, monitor, or drives to successfully POST.
    Now start connecting the rest of the devices starting with the monitor, then keyboard and mouse, then the rest of the devices, testing after each step.
CPUs
