Solved
Will this power supply be compatible with my computer?
Currently I have a m2n-e mobo and this power supply:
http://secure.ncix.com/products/index.php?sku=15859
I was wondering if this power supply will fit in my rig:
http://ncix.com/products/index.php?sku=26414
Also how can you tell if a power supply will be compatible?
5 answers Last reply Best Answer
More about will power supply compatible computer
  1. The width and height are standard among PSUs of that form factor, it might be a tiny bit longer but it should still fit fine.
  2. what about pins? My friend told me I have to look at the pins?
  3. Best answer
    The 650TX uses a 20+4 pin main so it works with 20 or 24 pin boards, a 4+4 cpu power so it works with 4 pin ATX systems or 8 pin EPS systems, and uses 6+2 PCI-E power connectors so it will work with 6 or 8 pin setups, it has more connectors than a reasonable system needs so you dont need to worry about the pins.
  4. if ur case is atx and ur psu is atx then it fit.
    there is a standard for psu's
  5. Best answer selected by j8262345.
Power Supplies Computer Compatibility Components
