Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > Inspiron 5150 Power Loss (in Response to Sudden Movements?)
Forum Laptops & Notebooks : General Laptops & Notebooks - Inspiron 5150 Power Loss (in Response to Sudden Movements?)
Archived from groups: comp.sys.laptops (More info?)
Im sitting still and tense as I write this because my laptop is being a real
problem ...
My Dell Inspiron 5150, maybe 18 months old, this evening began loosing
power, as best I can figure in response to suddenn movements, or perhaps
gentle taps to its back (port area). This came out of the blue; nothing has
changed recently and it has experienced no physical trauma. It just keeps
shutting down in an instant unless I am very very VERY careful with it. Its
presumably a hardware problem (though theres no rattle!) but does anyine
have any idea what it might be? Its no longer under warranty :(
Appreciate it,
El.
Sponsored Links
"Ellarco" <nobrow@eircom.net> wrote in message
news:jxWfd.40217$Z14.14703@news.indigo.ie...
> a real problem ...
> perhaps gentle taps to its back (port area). This came out of the
> blue; nothing has changed recently and it has experienced no physical
> trauma. It just keeps shutting down in an instant unless I am very
> very VERY careful with it. Its presumably a hardware problem (though
> theres no rattle!) but does anyine have any idea what it might be? Its
> Appreciate it,
> El.
On battery, AC power, or both?
Q
Reply to Anonymous
"Quaoar" <quaoar@tenthplanet.net> wrote in message
news:F_qdnQgKOrCVrhzcRVn-og@comcast.com...
>> real problem ...
>> has changed recently and it has experienced no physical trauma. It just
>> keeps shutting down in an instant unless I am very very VERY careful with
>> it. Its presumably a hardware problem (though theres no rattle!) but does
>> anyine have any idea what it might be? Its no longer under warranty :(
>> Appreciate it,
>> El.
> Q
Should have said. Both.
Ive just had it to pieces and saw nothing obvious (loose, burnt, ...). Its
crazy. I just have to tap it and off it goes.
Reply to Anonymous
news:ssagd.40284$Z14.14737@news.indigo.ie...
>>> being a real problem ...
>>> loosing power, as best I can figure in response to suddenn
>>> movements, or perhaps gentle taps to its back (port area). This came
>>> out of the blue; nothing has changed recently and it has experienced
>>> no physical trauma. It just keeps shutting down in an instant unless
>>> I am very very VERY careful with it. Its presumably a hardware
>>> problem (though theres no rattle!) but does anyine have any idea
>>> Appreciate it,
>>> El.
>> Q
> Its crazy. I just have to tap it and off it goes.
The obvious first place to look is the area on the mainboard around the
AC jack for a crack, etc., due to flexure of the AC adapter plug. That
the problem exists on battery points to the entire AC/battery switching
circuit involved which is probably deeper in the board than just the
area immediately around the AC jack. In addition, since the problem is
intermittent it might be a simple break in a board trace or solder joint
that can be repaired with conductive epoxy or solder.
Another area might be the power key/cable to mainboard. In any event,
if you open the case, take a look at everything very closely before
removing the next part or cable. You might get lucky and find the
source through inspection.
BTW, check that the battery is firmly inserted.
Q
Reply to Anonymous
news:9_KdnayIt58fNxzcRVn-iw@comcast.com...
>>>> real problem ...
>>>> perhaps gentle taps to its back (port area). This came out of the blue;
>>>> nothing has changed recently and it has experienced no physical trauma.
>>>> It just keeps shutting down in an instant unless I am very very VERY
>>>> careful with it. Its presumably a hardware problem (though theres no
>>>> rattle!) but does anyine have any idea what it might be? Its no longer
>>>> under warranty :(
>>>> Appreciate it,
>>>> El.
>>> Q
> The obvious first place to look is the area on the mainboard around the AC
> jack for a crack, etc., due to flexure of the AC adapter plug. That the
> circuit involved which is probably deeper in the board than just the area
> Another area might be the power key/cable to mainboard. In any event, if
> you open the case, take a look at everything very closely before removing
> the next part or cable. You might get lucky and find the source through
> inspection.
> Q
Had another close look but cant see anything. Im starting to think that it
might be hard-drive related though (for no particularly good reason).
Guess Ill just have to send it off to be fixed ... Ch-ching :(
Reply to Anonymous
There are 1274 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
