So, I'm looking into getting a new gaming rig. Don't want to spend a fortune, of course, so I'm choosing between an i5 and a 920-ish i7. I'm a bit confused on some of the P55 vs X58 differences, at least for how they relate to gaming. It's always mentioned, but never really elaborated on.
I'm also a semi-huge gamer, and plan to get an Nvidia 400-series card, but I'd also like to use my older 8800 (which is admittedly the newest part of my current rig) card for physX, or is that not a good idea / possible? Would it be better to get a cheaper, less power-hungry dedicated physX card?
I'm also really interested by the idea of liquid cooling, but horror stories have kind of put me in a wary place. I'm looking at a Corsair H50 closed system, but considering that I hear the 400 series video cards run hot, I might want to go VGA cooling as well (Or more importantly.) What would you folks recommend for a new liquid-cooling acolyte? I'm assuming I can't hook that H50 up to a VGA cooler due to the 'closed system' bit.
Finally, is there any notable difference between dual-channel and triple-channel memory? I've heard 'no' but again I'd like some user feedback. Anything's probably better than my current DDR-based 32-bit system.
I've been out of the loop a little over a year due to military deployment, so I'm missing out on a fair bit of data, and what I can find is mostly from the start of the year. Is there anything particularly groundbreaking due to be coming out in the next few months?
Oh! And did they ever take care of that whole problem with Vista/7 and the creative x-fi cards? I remember there being some grief with those when I left. I have one of the older x-fi cards, but it still works quite well and the initial problems with Vista were keeping me from upgrading from XP and... I confess, I never did get around to it. Probably for the best, now that 7's out.
Sorry for the massive ball of questions. Pre-emptive thanks for all the help!
