Solved
Power Supply Cable Question
i recently recieved a used power supply
http://www.thermaltakeusa.com/Product.aspx?S=1172&ID=1534
(Thermaltake 450W W0146RU)
but it did not come with all the cables i need
im looking to add an optical drive (or two) and i need the cable that would run from the PSU to the back of it
i believe what i need is a P6 or P4 cable which would plug into the PSU with a 4pin molex on the other end which would plug into the back of the optical drive?
but i couldnt really find anything like that on newegg so i figured i was looking for the wrong thing
so can anyone tell me what cable(s) i need and where to find them...
THANKS
7 answers Last reply Best Answer
More about power supply cable question
  1. I believe you want a Stylish Y-cable or two from here :)
    http://thermaltakeusa.com/Products.aspx?C=1154
    is that what you were after?
    Moto
  2. +1^
  3. umm i need a cable that plugs physically into the PSU
    i dunno how those 4pins would plug into the PSU because all it has is that 6 pin input slot
  4. oh,you dont have any molex line to feed that adaptor off? sorry man, I didnt realise that :)
    possibly contact Thermal's helpline and explain the situation,
    quick Goosh isnt turning anything up I'm afaid :)
    Sorry mate,
    Moto
  5. Best answer
  6. nice one Dell :) ty man
    I couldnt find anything hehe
    Moto
  7. Best answer selected by newbosaurusrex.
Power Supplies Optical Media Cable Components
