G'day Folks,
This is my first ever build from scratch and after the research i have done, i have picked the following parts. I will be using it for gaming on both monitors and whatever else. I know its probably a bit more powerful than i need but i like doing things well the first time
Please let me know if it will all fit together and run smoothly because currently that is my biggest worry. Also, if there is any extra insider knowledge to help me set it up? If I buy everything on this list will i have what i need to put it together? Am i missing anything?
CD Drive:
ASUS DRW-24B1ST Black Internal DVDRW SATA
Case:
Fractal Design Define R2 Computer Case Titanium FD-R2T
Graphics Card:
Asus ENGTX4702DI1280MD5 GTX470, 1215MB, 320BIT, DDR5, 607Mhz, 2DVI, mHDMI, FAN, PCIE, ATX
RAM:
Corsair CMG6GX3M3A2000C8 6GB (3x 2GB) (2000MHz) DDR3 For X58 MB/ i7 Core, 3x240-pin
CPU:
Intel BX80601930 CORE i7 930/ 2.8GHz/ 4.8GT QPT/ 8MB CACHE/ LGA1366
Primary HD:
INTEL SSD X25-M 80GB NOTEBOOK/ DKTOP INTEL X25-M SOLID-STATE DRIVE, 80GB SATA II 2.5", MLC, HIGH
Secondry HD:
Seagate ST31000528AS 3.5" CUDA7200.12, 1TB, 7200RPM, 32MB, SATA2 3.0GB/ S, NCQ, 3YR
PSU:
COOLER MASTER EXTREME POWER+ 650W V2.3 RS650-PCARE3
MotherBoard:
Asus P6X58D-E MB, Socket 1366, X58, 6xDDR3, RAID, 3-Way SLI, CrossFireX, SATA3, USB3.0, 2xGigabit
Monitor:
BenQ G2420HD 24.0" Widescreen LCD Monitor Piano Black, Full HD 1920x1080, HDMI, 2ms, 40,000:1 x2
Thanks ahead for all your help folks!
Guy.
CD Drive:
Case:
Graphics Card:
RAM:
CPU:
Primary HD:
Secondry HD:
PSU:
MotherBoard:
Monitor:
Guy.
