New build - suitable power supply
Dear Forum,
I'm building a new PC and i've got everything down, what i'm struggling to find is a PSU that can deliver enough power to all my components. So i'm not sure how to take into account the 12V 5V and 3V rails
MB – ASUS P6X58D Premium
RAM – 6G Kit DDR3 1600 Patriot Skill
HDD – Seagate 1TB
CPU – i7 930 X58
GPU – 1280MB GTX470 Inno3D
SATA Blu-Ray Combo Samsung
Haven't got a case yet
I calculated that the system should use 430 watts under 90% load, but I do want some headway when it comes to the power consumption
Those are the components I was trying to put together
Any help would be appreciated! :)
4 answers Last reply
More about build suitable power supply
  1. I'd use one of these if you were certain that you won't SLI:
    Corsair 650TX (52 amp 12 volt rail)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
  2. I was looking at the CM GX 750 aswell
    Definately not going into SLI
    Looked at the prices between the two
    CM GX 750 = 129
    Corsair 650TX = 114
    Might end up going with the CM?
  3. Thank you for the links btw!
Homebuilt Power Supplies Systems Product
