Hi everybody, I am new to both the forum and building my own pc. I'm really looking forward to this experience, but thought I'd get some advice before spending my money.
I am a college student with a fairly low budget ($800), so keep that in my mind if you recommend any components. This rig will be mostly for gaming and watching movies, which is kind of tough with a budget.
Here's my build so far:
Case+PSU- Apevia X-DREAMER3 Mid Tower Case w/ 450W PSU ($60 after rebate)
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5250569&CatId=1509
MOBO- Gigabyte MA785GM-US2H ($70)
http://www.tigerdirect.com/applications/searchtools/item-details.asp EdpNo=4936681&SRCCODE=GOOGLEBASE&cm_mmc_o=VRqCjC7BBTkwCjCECjCE
PCU- AMD Phenom II X4 940 Black Edition ($118)
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103644&nm_mc=OTC-Froogle&cm_mmc=OTC-Froogle-_-Processors+-+Desktops-_-AMD-_-19103644
Video Card- EVGA GeForce GTX 260 Core 216 Video Card ($180 after rebate)
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4369730&CatId=3585
HDD- WD1001FALS Caviar Black Hard Drive - 1TB ($95)
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4034139&CatId=139
*considering the WD 750Gb for $75 but I like the idea of having 1TB
Memory- Crucial 2048MB PC6400 DDR2 800MHz (x2 for $96)
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3322895&Sku=C19-6032
Optical Drive- Lite-On IHAS22406 Internal DVD Writer ($25)
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=5204603&pagenumber=4&RSort=4&csid=ITD&recordsPerPage=5&body=#ReviewStart
*This is OEM, so I'm not sure if I will need to purchase a cable
Monitor- 22" ViewSonic VA2223wm DVI 1080p Widescreen LCD Monitor w/Speakers ($145)
http://www.geeks.com/details.asp?invtid=VA2223WM-PB-R&cat=MON
That should be it, since I already have a keyboard, mouse, and speakers and I will probably just be using the MOBO soundcard.
Total price- $790, which might come down after bargain shopping.
Trying to keep this below $800
