Yes No
Ads
Tom's Hardware > Forum > Motherboards & Memory > Motherboards > "Chassis Intruded! Fatal Error. System Halted."
Forum Motherboards & Memory : Motherboards "Chassis Intruded! Fatal Error. System Halted."
Hello everyone, bit of a head-scratcher here for you all- any help/ideas would be appreciated.
I recently (6 months ago) built a new rig. Main component of interest for this problem would be the MoBo, a Asus M4A78T-E.
It worked fine for the first few weeks. Nothing to complain about, until I started playing a rather graphics intensive game. Then I would experience random system lock-ups. (I attributed it to the game, not the GPU, as other games seemed fine).
Then about a month in something odd happened, I got system lock-ups doing non-gaming activities such as Internet Browsing or Word Processing. It didn't happen VERY often maybe once every 2 days. (I know that seems often, but I was overly tolerant.)
Then something else happened around the same time. Sometimes during boot-ups, after the Bios Splash screen I would get the error "Chassis Intruded! Fatal Error. System Halted." I could get around the error by simply restarting, and the system would work fine afterwards.
Recently, the problem has gotten much more persistent, happening sometimes multiple times a day. The Chassis Intrusion error always follows the system lock-up upon the first restart.
Things I have tried thus far:
Reset the CMOS.
Reseated the Chassis Intrusion Jumper Pin.
Tried booting up without the Chassis Intrusion Jumper Pin. (Won't Even Boot, gives a constant Chassis Intrusion Error.)
Any ideas?
Thanks.
Reply to domobon
Is there a setting in the bios for enable/disable chassis intrusion?
If so just disable it..
------------------------------ Gigabyte GA-EP45-UDP3L Intel E8400 C2D @3.2Ghz OCZ 1066 Vista Platinum DDR2 ram, BFG GTS250oc 512MB, Corsair vx550 Power Supply, AOC 23\" 1920 x 1200 LCD monitor, Logitech Z-2300 speakers with Missil satilite speakers.
Reply to johnnyq1233
Sadly, for the Asus M4A89T-E there is no such option. (Unless I am mistaken, but as far I have seen there is not.)
The only way to enable/disable it is manually via the jumper pin.
Reply to domobon
RMA it.The problem isn't about the Chasis Intrusions.It's about what happend before that, reguarding the random system lock ups.Just RMA the board.
Even if you bought the board 6 months ago it should still be under Warranty with Asus.
Message edited by purple stank on 03-27-2011 at 05:13:55 AM
Reply to purple stank
There are 2001 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Memory for GIGABYTE GA-G41MT-S2P
By fantastik250, 1 hour ago:
Take a look at this and see if you like it. http://www.newegg.com/Product/Prod [...]...
Best offers
Top experts
