Yes No
Ads
Tom's Hardware > Forum > Graphics & Displays > Nvidia > Framerate problem with GTX 285
Forum Graphics & Displays : Nvidia Framerate problem with GTX 285
Hello, I'm new to this forum
I have a problem when playing some games, like assassin's creed, fallout 3 and a few others...
Anyway, I think should be running them pretty smoothly, but that doesn't happen.
I've got:
Windows 7 64x
nForce 730i
Intel Core 2 Quad Q6600 @ 2.4GHz
2x2Gb Ram Corsair Xms 800 MHz
EVGA GeForce GTX 285 SSC 1GB
I'm running with a little lower clock on the video card, almost stock-like and I've disabled that hybrid sli with the motherboard's video card, so I'm using only the GTX 285.
I've tried some driver like the latest 197.45 and also a 187.66 that someone recommended.
But when I run Assassin's Creed (the first one, not Assassin's Creed II) on 1440x900 60Hz, All maxed out, I get an average of like 25-30 fps. And I see on forums people saying that with specs similar to mine they get a smooth 60 fps.
Plus sometimes I get error that the some dll of the driver has crashed and the game just stops working.
Some games run smooth like Prototype and Dragon Age: Origins, so I don't know why I can't play Assassins Creed maxed out with at least 45-55 fps always.
I do get good fps if I lower the graphic settings, but a gtx 285 should run it at max well, right?
If anyone had any suggestions I would be glad to hear
Reply to brunoyujikc
try re-installing the driver. remove the driver and then use driver sweeper program to remove any left over by the driver before reinstalling the driver
Reply to renz496
I did what you said, took me some work since the stupid windows 7 always tries to install its terrible stardard drive
But I did uninstall the drivers and the run driver sweeper to be sure that there was nothing left. Then rebooted and installed the brand new 197.45 drivers from nvidia.com, still nothing.
I run Assassin's Creed and it starts and 35 fps, but when I get to the streets it goes down do 25 and it stays like that. I thought it might be my processor or memory bottlenecking, but a Q6600 should be able to run this game, right?
I'll see if I can OC the processor, but I'm not sure I'll be able to because of my 800MHz RAM.
If anyone else had any solutions to my problem I would appreciate.
Also I ran Assassin's Creed Dx10 and controlled my fans manually to 75% speed, forgot to check my temperatures but I'm pretty sure they're not high, my gtx285 runs at 42C idle.
And I think overheating is out of question I usa a HAF Coolermaster case, with 3x23cm fans(side, front and top) and a 12cm high rpm fan on the back.
What's your PSU ?
------------------------------ Antec902\RampageII extreme\i7 930 @3.8Ghz\Magahalems+2x Zalman F3BL\G.skill 6GB 1600 @1734Mhz 8,8,8,24\Force3D 5870\GB 8800GT PhysX\OCZ Vertex2 60GB\2x WDC Green 1TB RAID0\FSP Epsilon 800w\Sony 24x\3x BenQ T2200HD EF\Razer DeathAdder\MS Reclusa\Win7 x64
Reply to avatar_raq
There are 2001 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Graphics Card Help for a Casual
By geofelt, 1 hour ago:
As a standard, a pci-e x16 graphics card slot can deliver up to 75w to a graphics card...
Best offers
Top experts
