I just happen to have the Lancool Dragonlord PC-K60 for my own personal pc.
As others have suggested you can mount the psu in the bottom of the case so that the psu pulls in fresh air from the opening in the bottom of the case and exhausts hot air out the rear panel. It will work providing several conditions are met.
1. The case must rest on a flat surface such as a desk, stand, or wooden floor. There has to be sufficient clearance for air intake. Placing the case on a carpeted floor will block air flow.
2. There must be sufficient ventilation, airflow, and cooling for other components. For example, if the video card is located immediately above the psu and running hot, then the psu fan could be used to help exhaust the hot air from the video card.
Here is an example of a few minor changes I made to my Dragonlord case to improve ventilation, airflow, and cooling:
http://www.johnnylucky.org/dragon-lord/index.html
