Can I safely use a 300W power supply to replace a 250W bad unit in my eMachines
Last response: in Components
- What Power Supply do I need, 300W or 250W ? - Forum
- What power supply unit should I use? - Forum
- A Compatible Power Supply Unit to Replace Original? - Forum
- Can I safely replace my ViewSonic VE510b's faulty power supply with ANY equivalent PSU? - Forum
- What type of power supply and graphic card can i use to replace the ones in my HP pavilion? - Forum
- Can you use a 250W power supply for a 400W card? Forum
- SolvedIs it bad to use a 550W power supply on this? Forum
- Will a 400w power supply be safe where a 250w was Forum
- EASY TO USE and RELIABLE Power Supply Unit (£70 Max) Forum
- Replacing the power supply unit to make way for dedicated graphics card. Forum
- SolvedDo cpu power supplies go bad if never used Forum
- Replaced a bad power supply but still isn't working. Need help. Forum
- selling old tower power supply units-used Forum
- SolvedIs it safe to use black tipped power supply? Forum
- Are US bought power supplies safe to use in New Zealand? Forum
- SolvedHas anybody used one of these power supplie units? Xigmatek Centauro 800W Modular 80+ PSU Forum
- Generic power supply units...are they really that bad? Forum
- Emachine power supply bad? Forum
- I've just replaced my power supply. Motherboard. Graphics cars CPU and ram. My pc loads up and asks if I want to start in safe Forum
- Replace 8800gt using Dell 375W power supply Forum
- More resources
Read discussions in other Components categories
And the one I have in it now is an atx-300-12e-d. Should I be concerned with this one too? Or could I be so lucky that the 'd' means they have identified the problem and fixed it, thus giving it a slightly different identification? I'm guessing my luck isn't that good, but if you never hope for something...you may never get it.
