Hi, yesterday I transferred all my files from my 2TB HDD onto a newer, quieter 2TB HDD and although all the files are there, I'm having problems with other elements. Basically, the Desktop and Taskbar was blank when i removed the old drive and put in the new, but now I can't put any files onto the task bar or desktop. I can access the files, but not move them where I'd like.
Also, some of my files on my SSD now say something like 'file path incorrect' because the old drive is gone.
Is there anyway to fix my issues? Get my folders back that are in my SSD?
Thanks in advance
Thanks in advance
