phornick Honorable Aug 24, 2012 4 0 10,510 Aug 25, 2012 #1 my Lenovo has an eSATA/USB port but I can't seem to connect a USB connector directly to this port - do I need an adaptor?
kenrivers Illustrious Dec 29, 2010 6,684 6 37,015 Aug 25, 2012 #2 The connector won't fit or is not recognized when plugged in? Upvote 0 Downvote
phornick Honorable Aug 24, 2012 4 0 10,510 Aug 25, 2012 #3 kenrivers : The connector won't fit or is not recognized when plugged in? The connector won't fit.... thanks for your response Upvote 0 Downvote
kenrivers Illustrious Dec 29, 2010 6,684 6 37,015 Aug 25, 2012 #4 Since it is a combo port you do not need an adapter. Do you have a picture of the cable you are using or know where I can see it? Something is quite odd if it does not fit. Upvote 0 Downvote
