Alright here is what I have...
Lancool PC-K60 with 4 fans
Asus P7P55D-E Pro with a 3-pin power fan connection, a 4-pin chassis fan, a 4-pin CPU fan (for heatsink fan), and a 3-pin chassis fan.
First of all what is a power fan connection and whats the difference between it and a chassis fan connection?
The dilemma is i have more case fans than fan connections. I have heard that you can connect your case fans to the PSU via the included molex adapter.
I have also heard some people suggest that ALL of your case fans are connected to the PSU and not the mobo. This reduces the current coming through the mobo. However I only have one molex adapter I believe.
What should I do? This is my first build by the way. Thanks.
