Solved
HP 3115m Solid State Drive Problems
Alright as the title says it all, I am using a HP 3115m netbook and I just installed a ADATA S510 120gb ssd. I realize that I can't have max performance especially because the netbook only has SATA 2, but I should be getting higher read and write speeds than 193MB/s read and 145MB/s Write. I have gone through the HP bios and it is of course limited to what a 5 year old could easily deal with. I can't find a way to change to AHCI mode or anything. I am throwing myself at your mercy here because I am at wits end. Any help would be greatly appreciated!
Thanks!
3 answers Last reply Best Answer
More about 3115m solid state drive problems
  1. Best answer
    What are your expectations? This is a relatively slow system and the transfer speeds that you achieve seem acceptable.
  2. Its more I needed an opinion from someone who has more knowledge on the subject than I did. If these speeds seem acceptable due to the relativly slow nature of the system than I am happy with it. Its still loads faster than the original piece of junk 5400rpm hard drive that it came with. Thanks for the help
  3. Best answer selected by eggbrook.
SSD Solid State Hewlett Packard Netbooks Storage
