Solved
16:9 23" Monitor vs. 16:10 22" Monitor
Hey,
I'm trying to decide between these two monitors from Asus:
23", 16:9, $190 - http://www.newegg.com/Product/Product.aspx?Item=N82E16824236059
22", 16:10, $160 - http://www.newegg.com/Product/Product.aspx?Item=N82E16824236050
I'm going to be using it pretty much solely for gaming, which would you recommend more? for $30 more, you get the higher 1920x1200 resolution (vs. 1680x1050) and wider size, but you also get a lower screen size ratio. I'm currently accustomed to a 16:10 monitor, so I'm wondering how much different it will feel.
Any thoughts/ideas?
I will hopefully get out to Best Buy/Fry's sometime soon and just look at some myself to see, but it would be awesome if you guys could give me some help! :)
FrPSh
4 answers Last reply Best Answer
More about monitor monitor
  1. Best answer
    I'd go for the 16:10 monitor, because mainly that's the resolution which gamers play at. Mainly 4:3 is old skool, 16:9 is for movies or HD content, and 16:10 is for gaming and general computing, although more and more monitors seem to be made in 16:9 resolution nowadays.
  2. Yes, go for the 16:10, I changed to 21'5 / 16:9 monitor and I'm crying everyday for my old 19' /16:10 monitor :P
  3. Yes, go for the 16:10, I changed to 21'5 / 16:9 monitor and I'm crying everyday for my old 19' /16:10 monitor :P
  4. Best answer selected by FrPSh.
Graphics Cards Asus Screen Size Resolution Monitors Graphics Product
