[Solved] Help I have a problem about my Hard Disk
can some one help me I have had a 1000.00 GB hard drive pout in to my computer.
But wen pouting software in it will only take as much as a 125GB hard drive will take.
J. J. Benge.
2 answers Last reply
More about solved problem hard disk
  1. What kind of motherboard are you plugging into? it might be too old to support drives of that size. also, check with diskmanagement and make sure it isnt partitioned out into other drives.
    right click Computer -> Manage -> Disk Management
    What do you see?
    Also, check the drive's manual. sometimes you can limit the drive's capacity with a jumper.
  2. thank you very much for your advice it might answer my problem.
Hard Drives Computer Software Storage
