Need Help With Getting Started (All Parts Came Today)
Hey guys,
I am getting all my parts in today from newegg to build my new computer. This is my first build so I have a few questions on setting up the software. I bought this MOBO GIGABYTE GA-790XTA-UD4 AM3 AMD 790X SATA 6Gb/s USB 3.0 ATX AMD Motherboard and I have heard through reviews that you need to update the BIOS right away. I don't really know how to do that. I went to the GIGABYTE website and found the latest BIOS update and downloaded it. What do I do with this software once I start up my computer and enter the BIOS?? I am not really sure how to set this up or install Windows 7 from a freshly built PC.
Any suggestions, advice, answers, or direction to other articles would be very helpful because I want to build this PC today and have Windows 7 64-bit up and running
:bounce: :bounce: :bounce:
5 answers Last reply
More about need started parts today
  1. The board's instruction manual will tell you how to update the BIOS. You'll need a flash drive.
    I don't think it's actually necessary to need to do this right away. Unless you're using a CPU that isn't supported by the default BIOS (check Gigabyte's webiste, the only possible ones are the X6s), you shouldn't need to do this.
    As for Windows, you just get everything running, set the BIOS to boot from the CD, insert the Windows CD and restart. Then just follow the instructions on the screen. That's it. It's not any different from installing a program.
  2. Gigabyte goes all out with the info on bios updating. 3 ways to choose from:
    http://www.gigabyte.us/Support/Motherboard/HowToReflashBIOS.aspx
    Is this a OEM copy of windows or from an upgrade disk? Brand new HDD also?
    If you need help with assembly, this is the most in depth guide I've seen and our very own forum rat Techmo34 wrote it. If you use it, give him a PM saying thanks.
    http://www.tomshardware.com/forum/274745-31-step-step-guide-building
  3. What are your full specs? Do you have a windows 7 DVD?
    Generally they ship out boards with the newest BIOS so you hopefully wont need to update it.
    To install windows, after you have assembled everything, when you boot it up, go into BIOS, set your RAM timings and voltage and set your DVD drive to be the first item in the boot order, it will boot off of the windows 7 dvd and go from there.
  4. how do I find out if my Windows 7 is OEM or Full version? I got it off the MSDNAA site. Thanks for the help and input.
  5. That will be a full version ISO. Do you know how to turn an ISO into an actually DVD?
Build Systems
