Well i've got a fresh built pc, but the psu i bought for it was DOA(Corsair650TX) so im RMAing it. While I wait for the replacement i'm using an Antec Earthwatts 500W. What I want to know is can the Antec safely power all my parts if I were to play a typical 3d mmorpg game, thats not very graphic intensive at all. Game is Global Dekaron if that helps.
My parts are:
GPU: GTX 460 1GB Superclocked
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130567&cm_re=EVGA_GTX_460_1GB-_-14-130-567-_-Product
MOBO: ASROCK 870 Extreme3
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157198&cm_re=asrock_870-_-13-157-198-_-Product
CPU: AMD Phenom II x4 945 Deneb
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103809&Tpk=945%20deneb
RAM: Corsair XMS3 4GB 1600
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145260&cm_re=corsair_xms3-_-20-145-260-_-Product
HDD: Samsung Spinpoint F3 500GB 7200RPM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152181&cm_re=samsung_spinpoint_F3-_-22-152-181-_-Product
Case: Coolermaster 690 II Adv (Fans and some LED)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119216&cm_re=coolermaster_rc_692-_-11-119-216-_-Product
And some ASUS DVD Drive.
I'm currently typing from said computer, but have only important software, drivers, ventrilo, and my browser running/installed. Would it be safe to increase the power output by playing low-medium requirement games, or should I wait?
PS: The Antec Earthwatts 500w that I have is an older model(silver/grey), not the newer(dark green color) one that you would find on newegg if you searched it now.
My parts are:
