Solved
Help picking a Cpu and Motherboard
Hello Toms need help picking a Cpu and Mobo combo Light to mid gaming, PowerPoint, photoshop, internet. Just finished a AMD 1055t build, Building a second computer. Have $450 for CPU and Motherboard. Planning to OC. Here is what I have...
Corsair 650HX
Gskill ddr3 1600 ripjaws
5870
ssd for os
Choices....
Intel Core i7 860 Processor 2.80 GHz 8 MB LGA1156 CPU I7-860BOX
or
Intel Core i5-760 2.8GHz 8 MB LGA1156 Processor BX80605I5760
or
Intel Core i7 Processor i7-930 2.80GHz 8 MB LGA1366 CPU, Retail BX80601930
or
Phenom II X4 965 Black AM3 3.4Ghz 512KB 45NM 125W 4000MHZ
Intel version mobo Something equal to M4A89GTD Pro (I have it and like the a.i. tweaker overclock utility)
7 answers Last reply Best Answer
More about help picking motherboard
  1. Get the i7-860 CPU paired with a P55 mobo like this one:
    GIGABYTE GA-P55-USB3 LGA 1156 Intel P55 USB 3.0 ATX Intel Motherboard
    I think you wouldn't have the money to go with an i7-930 CPU and a X58 mobo, so this is the best solution.
  2. If you do go amd, the 965 is a factory overclocked 955 and since your overclocking anyways its a waste of money.
    Hello the x-58,chipset , so any x-58 board?? and a i7-930
  4. Best answer
    You will have to increase your budget to get an X58 mobo and the i7-930. Best mobos come from ASUS, Gigabyte. There are also some good mobos coming from MSI.
  5. Done i'm gonna do it.
  6. Best answer selected by miwanuma.
  7. np:D
CPUs Intel i7 Motherboards Intel Product
