G
Guest
Guest
Hi, I'm wondering if im getting enough voltage for my rig. It would help me if this is one of the problem whereas I have cold boot problems sometimes. I currently have a
COOLER MASTER eXtreme Power Plus RS-500-PCAR-A3-US 500W ATX12V v2.3 Power Supply
Output: +3.3V@22A, +5V@25A, +12V1@18A, +12V@218A, -12V@0.5A, +5Vsb@2.5A
I'm not real good with power supply amps and what not but here's the specs of my rig
and already my video card minimum req. are: Minimum of a 450 Watt power Supply
(Minimum recommended power supply with +12 Volt current rating of 24 Amps.)
Specs:
AMD Phenom x4 955 3.2ghz
1x GTS 250 512mb DDR3
2x 1GB Corsair XMS2
1x SATA Hitachi 750GB H/D 7200rpm
1x ASUS CD-/+RW/DVD-/+RW
1x PC-e TrendMicro Ethernet Adapter
1x 200mm Case Fan w/ LED
3x 120mm Case Fan w/ LED
1x Antec 900 Case
My question is it says i need 12v@24 or more amps and the specs of my power supply says it gives off only 12v@18amps. Do I need more juice for my rig?
PS. With the cold boot problems, I boot up after 4+ hours and after my desktop appears I just get a blank black screen with no mouse cursor. Have to hard reset to get it stable, it's stable after 1 reboot it's weird. Planning to add more ram once I recieve my RMA'd 4gb ram back from corsair. Thanks for you help.
Specs:
2x 1GB Corsair XMS2
1x Antec 900 Case
