Solved
Will this power supply run a GeForce 9800 GTX/GTX+?
Link:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817103014
Just curious if that is a sufficient power supply to run a GeForce 9800 GTX/GTX+
Thanks!
4 answers Last reply Best Answer
More about will power supply geforce 9800
  1. Min recommend PSU is 450w, where that is a 650w, so yes it would run it. But it's probably worth typing your system info into one of those online power supply calculators to check that your other hardware isn't draining way too much power. In the case that it does use heaps of power, you might want something a little stronger. However, if you are using SLI which is two cards next to eachother I assume you will need 2x 450 (not 100% sure though).
  2. Best answer
    I'll give you an answer: Yes, that is enough for two 9800GTX. However, I've never even heard of that brand, thus I recommend you to get a name brand (E.g. Corsair), or else you could suffer harch consequences (e.g. random system shutdowns, caused by the power supply's inability to deliver a constant (or not enough) to your motherboard's 12V.
    Good Luck.
  3. The simple answer is Yes!
  4. Best answer selected by Mpeachy.
Power Supplies Gtx Geforce Components Product
