First System Build - Opinions/Advice welcome
APPROXIMATE PURCHASE DATE: Anytime between now and x-mas
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: gaming, surfing the internet, watching movies
PARTS NOT REQUIRED: keyboard, mouse, monitor & PSU (OCZ Stealth Extreme 600W)
PREFERRED WEBSITE(S) FOR PARTS: Scan, Microdirect, Novatech.
COUNTRY OF ORIGIN: UK
PARTS PREFERENCES: Open to suggestions
OVERCLOCKING: No
SLI OR CROSSFIRE: No
MONITOR RESOLUTION: 1920x1080 - Scalable
ADDITIONAL COMMENTS: N/A
Hi guys,
Looking for a little bit of advice:
First time round with a build, I've picked out what I think will work but I could be way off. Opinions would be welcome!
Coolermaster Storm Scout Gaming Case - £74
http://www.novatech.co.uk/novatech/prods/Components/Cases/Cases/Coolermaster/STORMSCOUT.html
Gigabyte GA-890GPA-UD3H AMD 890GX (Socket AM3) PCI-Express DDR3 Motherboard - £110
http://www.novatech.co.uk/novatech/prods/Components/Motherboards/AMDAM3AMDChipsetMotherboards/Gigabyte/GA-890GPA-UD3H.html
AMD Triple Core Athlon II X3 440 3.0GHz 1.5MB Socket AM3 - £64
http://www.novatech.co.uk/novatech/prods/Components/Processors/AMDAthlonX2AndX4/AMD/ADX435WFGIBOX.html
Western Digital 500GB hard disk drive Caviar SE16 SATA II 300 7200rpm 16MB - £35 (x2)
http://www.microdirect.co.uk/Home/Product/16566/Western-Digital-500GB-hard-disk-drive-Caviar-SE16
Sony AD-7241S Lightscribe 24X DVD+/-RW Dual Layer DVD-RAM SATA Black - OEM - £19
http://www.novatech.co.uk/novatech/prods/Components/OpticalDrives/SATADVDWriters/Sony/AD-7241S-0B.html
OCZ Memory 4GB (2x2048MB) Reaper HPC Edition DDR3 PC3-14400 1800 MHz RAM Dual Channel 8-8-8-27 Reaper HPC Heatsink - £112
http://www.microdirect.co.uk/Home/Product/37697/OCZ-Memory-4GB--2x2048MB--Reaper-HPC-Edition-DDR3
OS I am thinking Windows 7, 64-Bit... although I've never really understood the difference (Answer's on a post card please!).
I already have:
OCZ Stealth Extreme 600W PSU
Radeon 4890 X-Vapour 1GB DDR5
Monitor
Keyboard/Mouse
Main aim is a stable system, no overclock but as future proof as possible. Budget is about £600.
Cheers Guys,
Steve
4 answers Last reply
More about first system build opinions advice welcome
  1. Looks good nut get the Samsung 500GB F3 and the G-Skill 4 GB DDR3 PC10666 1333Mhz Kit CAS 8 Ripjaws Kit.
  2. The Samsung Spinpoint F3 or Seagate Barracuda 7200.12 500GB drives both use a 500GB platter which helps them to be faster than 500GB WD drives, as well as quieter, produce less heat and due to the fewer moving parts mean that there are less parts to fail.
    OCZ Ram is not really the best idea as they have reputation atm for having difficulties with mobos. Also you are unlikely to benefit from RAM faster than 1600mhz.
    Win 7 64bit will utilize all the RAM in a system, which will include the VRAM on the graphics card. I've also heard there are security benefits over the 32bit version, altho I'm not clear about what these are.
  3. Thanks Guys,
    If not the OCZ who would you go for? I had the option of OCZ 1800mhz or Corsair/G.Skill 1600mhz.
    Thanks for clearing that up for me.
  4. I'm not trusting my eyes atm because this looks like a FANTASTIC deal: G.Skill Eco 4GB (2x2GB) DDR3 1600Mhz CAS7 (7-8-7-24-2N) 1.35V £92
    Also I assume you made a mistake linking to the X3 435 rather than the 440.
Homebuilt Systems
